Error when running AI Agent node in n8n: SQLite issue
Hi n8n community. I’m facing an issue when using the AI Agent node in n8n.
CleanShot 2025-02-07 at 11.33.41
When running the workflow, I get the following error:
Problem running workflow
Could not locate the bindings file. Tried:
→ /usr/local/lib/node_modules/n8n/node_modules/sqlite3/build/node_sqlite3.node
→ /usr/local/lib/node_modules/n8n/node_modules/sqlite3/build/Debug/node_sqlite3.node
→ /usr/local/lib/node_modules/n8n/node_modules/sqlite3/build/Release/node_sqlite3.node
The problem is that my n8n setup does not use SQLite at all. I am running n8n with PostgreSQL as the database, but for some reason, the error indicates a missing sqlite3 or better-sqlite3 dependency.
What I’ve tried so far:
• Reinstalled docker build
• Updated to 1.77.3
n8n setup
  • n8n version: 1.77.3
  • Database: Postgresql (managed DB on another server)
  • n8n EXECUTIONS_PROCESS setting: own
  • Operating system: Ubuntu 24
I Have a same problem.
n8n version: 1.77.3
postgres database on Azure: 16.4 (Burstable, B1ms, 1 vCores, 2 GiB RAM, 32 GiB storage)
Running n8n via desktop app. (pnpm start)
OP: Windows 11
Error:
Could not locate the bindings file. Tried: → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\build\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\build\Debug\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\build\Release\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\out\Debug\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\Debug\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\out\Release\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\Release\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\build\default\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\compiled\22.13.1\win32\x64\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\addon-build\release\install-root\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\addon-build\debug\install-root\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\addon-build\default\install-root\node_sqlite3.node → C:\Users\Developer\Documents\project_presentation\node_modules.pnpm\sqlite3@5.1.7\node_modules\sqlite3\lib\binding\node-v127-win32-x64\node_sqlite3.node
You can fix it with the Dockerfile setting:
This is row from official Dockerfile from n8n, which I found. It works!
