Im trying to make my first AI workflow. Just a simple chat connected to an agent and a model. I have tried both Gemini and OpenAI models.
I also tried to just use the OpenAI node to check that connection and credentials work. In that node all works fine.
Feels like there is some setting I missing. But I cant figure it out
When I use the Open AI chat model I get Timeout error after a while.
TimeoutError: Request timed out. at wrapOpenAIClientError (/usr/local/lib/node_modules/n8n/node_modules/@langchain/openai/dist/utils/openai.cjs:13:17) at /usr/local/lib/node_modules/n8n/node_modules/@langchain/openai/dist/chat_models.cjs:1356:69 at processTicksAndRejections (node:internal/process/task_queues:95:5) at RetryOperation._fn (/usr/local/lib/node_modules/n8n/node_modules/p-retry/index.js:50:12)
When i try Gemini I get
TypeError: fetch failed at node:internal/deps/undici/undici:13178:13 at processTicksAndRejections (node:internal/process/task_queues:95:5) at _makeRequestInternal (/usr/local/lib/node_modules/n8n/node_modules/@langchain/google-genai/node_modules/@google/generative-ai/dist/index.js:290:20) at generateContent (/usr/local/lib/node_modules/n8n/node_modules/@langchain/google-genai/node_modules/@google/generative-ai/dist/index.js:692:22) at /usr/local/lib/node_modules/n8n/node_modules/@langchain/google-genai/dist/chat_models.cjs:332:24 at RetryOperation._fn (/usr/local/lib/node_modules/n8n/node_modules/p-retry/index.js:50:12)
