Error when using opther LLM which OpenAI compatible
Error when using DeepSeak API, which is OpenAI compatible
Tried to change baseURL and make it work with OpenAI model, but it’s getting timeout error
  • n8n version: 1.67.1
  • Database (default: SQLite): Postgresql
  • n8n EXECUTIONS_PROCESS setting (default: own, main):main
  • Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
  • Operating system:Linux
Hi @NarHakobyan
We’ve released a dedicated DeepSeek node with version 1.77, that should work - Give it a try and let us know!
