Error Workflow not triggering on timeout (n8n self hosted)
My Error Workflow is not triggering after my main workflow timesout. Even though I have a set up a max set up time and an Error Workflow.
I read somewhere that canceled workflows eventually turn into cancelled workflows but it has been more than 2 hours already and the workflows are still with status cancelled.
Can n8n currently handle this? Or is there a workaround anyone can think about?
Workflow Config:
Execution stops:
Error Workflow Executions: No execution
  • n8n version: 1.97.1
  • Operating system: Ubuntu 22
Yes seems like the execution will become canceled but will not trigger error workflow.
You can add as a feature request I guess.
However here is the solution that you can find thecanceled execution for specific workflow id
I think something not right. Because when filter status error : it didn’t contain canceled status.
You need to get all first and filter them out.
