Hi,
Is there a way to use the Excel 365 node to delete a row from the middle of a worksheet, and shift the remaining/lower rows up in to its place? (just like deleting a row using the UI)
Currently we can get the node to blank out the contents of the row we intend to delete by using the node’s Sheet->Clear function and specifying the row as a range. But I can’t find a way to make the remaining rows shift.
According to the API docs, there’s a “shift” parameter that could be set to “Up” to do this. Range: delete - Microsoft Graph v1.0 | Microsoft Learn
Thanks!
- n8n version: 1.70.2
- Database (default: SQLite): n/a
- n8n EXECUTIONS_PROCESS setting (default: own, main): n/a
- Running n8n via (Docker, npm, n8n cloud, desktop app): n/a
- Operating system: n/a
