Execute multiple sql statements or PL sql statements in using n8n-nodes-oracle-database-parameterization module in n8n
I’m unable to execute multiple sql statements one after another or PL/SQL in a single node.
set serveroutput on format wrapped;
DECLARE
v_new_id NUMBER; – Declare a variable to hold the returned ID
BEGIN
INSERT INTO schema.test_table (ID,NAME)
VALUES (schema.test_SEQ.NEXTVAL,‘test type’) – Assuming ID is from a sequence
RETURNING ID INTO v_new_id;
COMMIT;
DBMS_OUTPUT.PUT_LINE('Inserted ID: ’ || v_new_id);
END;
  • Database (default: SQLite): oracle
  • Operating system: mac os
