Hello.
Everything was working fine until recently. But now MySQL queries have stopped running.
Only simple sampling without conditions and only if I don’t use Execute SQL.
All other queries are terminated with “true” message and that’s it. No output data about the sample is given.
May be it is some kind of bug.
I have a selfhosted n8n instance. I updated to the latest version and the error is still there.
Please help the community and experts.
Hi @IndieDev, I am very sorry to hear you’re having trouble.
I’ve set up a dummy database including two tables with the below structure to reproduce this:
CREATE TABLE `authors` (
`id` int NOT NULL AUTO_INCREMENT,
`first_name` varchar(50) COLLATE utf8mb3_unicode_ci NOT NULL,
`last_name` varchar(50) COLLATE utf8mb3_unicode_ci NOT NULL,
`email` varchar(100) COLLATE utf8mb3_unicode_ci NOT NULL,
`birthdate` date NOT NULL,
`added` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
PRIMARY KEY (`id`),
UNIQUE KEY `email` (`email`)
) ENGINE=InnoDB AUTO_INCREMENT=101 DEFAULT CHARSET=utf8mb3 COLLATE=utf8mb3_unicode_ci
CREATE TABLE `posts` (
`author_id` int NOT NULL,
`title` varchar(255) COLLATE utf8mb3_unicode_ci NOT NULL,
`description` varchar(500) COLLATE utf8mb3_unicode_ci NOT NULL,
`content` text COLLATE utf8mb3_unicode_ci NOT NULL,
`date` date NOT NULL,
PRIMARY KEY (`id`)
I’ve then added a bunch of dummy data and tried a number of different queries using n8n, but was seeing the expected result every time, even when including conditions or joins. For example using this workflow:
Result:
Perhaps you can provide an example database schema and workflow using which your problem can be reproduced?
Thank you very much for your help.
Now everything seems to be working as it should.
The sql code is now running with conditions and subqueries.
