I’ve been testing out the Execute Workflow. However it keeps running after starting the next workflow. I’d just like to start the next flow and end the current workflow. How do I do that? In the original feature request it was stated that I could use the HTTP Request node to trigger a workflow. Is there a guide for doing this?
I figured it out. Just make sure your webhook flow is active.
