Executing one node several times with same output
Good day! Could you please advise how to set the following properly: Google Sheets node receives two variables: Indicator and the Number it appears. Indicator A appears 5 times, and Indicator B appears 3 times. Accordingly, it is necessary to append 5 rows in the Google Sheets showing Indicator A, and 3 rows showing Indicator B.
What will be the best solution for it?
@bganshin , does the workflow below address your challenge?
Thx for your help!
