Execution is not active
“In n8n, the execution is not showing as active. It says to switch to Pro, but even though I have made the payment, it still does not appear as active. What should I do?”
Hi @orkunacan ,
you should first check that your subscription is active and the payment went through. Try logging out and logging back in, or clearing your browser cache or using an incognito window, as sometimes the updated status does not show immediately. Make sure any required license key is correctly applied.
