When I try to open workflow execution details, the executions list shows them as “succeeded,” but the details panel just spins forever. I don’t see the JSON output of the run.
If I copy the execution back into the editor, I can see what it did — so the execution data is stored in Postgres, but the execution viewer in the UI fails to load it.
When
n8n version: 1.108.2
Database: Postgres 17 (via Docker, not SQLite)
n8n EXECUTIONS_PROCESS: (default →
main
Running n8n via: Docker (Dokploy stack with Traefik reverse proxy)
Operating system: Ubuntu 24.04 (inside VM on Proxmox)
Additional info:
I have
N8N_ENCRYPTION_KEY
set and data persisted in Docker volumes. -
Proxy headers come from Traefik.
Logs also show
[DEP0060] DeprecationWarning: The util._extend API is deprecated
, but I think that’s unrelated. -
Debug logging shows constant
Querying database for waiting executions
fromwait-tracker.js
