' Executions' won't load from home screen
Have my suspicions this is related to the last update (to 1.89.2). I don’t remember checking after the update (yesterday noonish), but this morning if I try to click on the Executions tab from the home screen, nothing happens. It doesn’t even put the underline like its attempting to do anything.
Viewing individual workflow executions works just fine, and they seem to be working fine. Just the display from the home screen.
Wish I had any meaningful output to put here.
Running under portainer, self hosted, behind nginx reverse proxy. No errors in the container logs or my nginx logs.
Chrome javascript console shows this error being thrown when I click on ‘Executions’:
index-CN4JmOoA.js:16090 TypeError: Failed to fetch dynamically imported module: https://mydomain.com/n8n/assets/ExecutionsView-Cm0glOsn.js
||triggerError|@|index-CN4JmOoA.js:16090|
||(anonymous)|@|index-CN4JmOoA.js:15885|
||Promise.catch|||
||pushWithRedirect|@|index-CN4JmOoA.js:15876|
||push|@|index-CN4JmOoA.js:15818|
||navigate|@|index-CN4JmOoA.js:15523|
||callWithErrorHandling|@|index-CN4JmOoA.js:2423|
||callWithAsyncErrorHandling|@|index-CN4JmOoA.js:2430|
||invoker|@|index-CN4JmOoA.js:9598|
ugh. and now it works again. looks like there was a cloudflare waf rule that kicked in for some reason. it had been fine until today. :man_shrugging:
