Expiring credentials making me crazy
Hey, someone help me please , what’s the solution?
I have a working n8n workflow, but due to expiring google drive and Sheets credentials (they always expire ) I can’t use the workflows all the time.
What is the solution? It must be some… Thanks!
If your Google Drive/Sheets credentials keep expiring in n8n, it’s usually because your Google OAuth app is still in testing mode (7-day token expiry) or offline access/redirect URLs aren’t configured correctly in Google Cloud, so the refresh token can’t renew automatically.
Hi @Renato_Matyasi Welcome!
For the expiring google console credentials please consider publishing your console app and that would make it work and not expire as it does now.
