I am experimenting with node development a little and wanted to add better description text to my expanded “Execute Workflow” node. Composite nodes - #10 by FelixL
I wanted to use something like:
subtitle: '={{"Workflow: " + $parameter["workflowId"]["cachedResultName"]}}'
But that does not work.
Following ts code works in the ts portion of the node
console.log(this.getNodeParameter('workflowId.cachedResultName', 0))
As i copied most of my code from the n8n API node, i tried it directly with the original n8n API node with an expression in n8n:
The variable selector correctly shows the cachedResultName, like I would expect from the code in the node.
But even when it automatically generates the expression for “cachedResultName” it returns: [undefined]
Is there a workaround for that issue, or am I just overseeing something?
And an off-topic question, is it possible for a node to change its icon dynamically? Have not tried that yet, but that would be super cool ^^
- n8n version: 0.225.2
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: Win 11
EDIT: updated subtitle code (originally copied debugging code…)
