External Secrets - Failure to Reload secrets from Azure Key Vault
When hooking up Azure Key Vault, we are observing that the connected service principal must have “Key Vault Secrets User” role scoped to the entire key vault. RBAC controls scoping the service principal to “Key Vault Reader” on the vault itself but only “Key Vault Secrets User” to specific secrets results in errors upon reloading secrets. Additionally, even if the service principal has “Key Vault Secrets User” role scoped to the entire vault, one disabled secret results in the same observed error.
The only successful outcome is to scope the service principal to either:
a) “Key Vault Reader” scoped to the key vault and “Key Vault Secrets User” scoped to each secret.
b) “Key Vault Secrets User” scoped to the entire key vault.
This sounds similar to Azure Vault stopped working with error 400 - #6 by jbenway
Error
Reload failed
  • n8n version: 2.14.2
  • Running n8n via n8n cloud
Welcome to the n8n community @milkyway9873
From my point of view, for now, the safest workaround seems to be granting Key Vault Reader at vault scope and Key Vault Secrets User only on the specific secrets n8n should read, and keeping disabled secrets out of the vault used by n8n. This preserves least privilege while still allowing reload to work.
Yeah this looks like a bug on n8n’s side, when it reloads it tries to fetch every secret in the vault and if even one is disabled or inaccessible the whole thing fails. For now I’d move any disabled secrets to a separate vault so the reload doesnt choke on them.
Just following up on the automated email ping to say that the problem hasn’t been solved. The workarounds mentioned are ok for the moment, but a bug has been raised External Secrets - Failure to Reload secrets from Azure Key Vault · Issue #28151 · n8n-io/n8n
