External Task Runner ignores module allowlist in Code node
  • When using Task Runners in external mode, the Code node cannot require any module (both built-in like path and external like xlsx). The runner throws “Module ‘???’ is disallowed”.
  • The same Code nodes work fine when Task Runners are in internal mode (or when runners are disabled).
Examples seen in the UI and execution logs when running a minimal Code node:
  • Built-in module:
    • Code: const path = require('path'); return [{ json: { ok: !!path } }];
    • Error:
      "errorMessage": "Module 'path' is disallowed [line 1]",
      "n8nDetails": {
        "stackTrace": [
          "Error: Module 'path' is disallowed",
          "    at /opt/runners/task-runner-javascript/dist/js-task-runner/require-resolver.js:16:27",
          "    at VmCodeWrapper (evalmachine.<anonymous>:1:243)",
          "    at evalmachine.<anonymous>:2:2",
          "    at Script.runInContext (node:vm:149:12)",
          "    at runInContext (node:vm:301:6)",
          "    at result (/opt/runners/task-runner-javascript/dist/js-task-runner/js-task-runner.js:165:61)"
  • External module:
    • Code: const XLSX = require('xlsx'); return [{ json: { ok: !!XLSX } }];
    • Error:
      "errorMessage": "Module 'xlsx' is disallowed [line 1]",
      "n8nDetails": {
        "stackTrace": [
          "Error: Module 'xlsx' is disallowed",
  • Note: Accessing process is intentionally blocked in the sandbox (ReferenceError: process is not defined), which is expected. The problem is specific to the module allowlist behavior in external mode.
Minimal reproduction 1 (built-in module):
Minimal reproduction 2 (external module):
  • Install package into the shared n8n data directory:
    docker exec -it n8n_app bash -lc ‘npm install --omit=dev --prefix /home/node/.n8n xlsx’
  • Workflow:
  • The node errors with “Module ‘path’ is disallowed” or “Module ‘xlsx’ is disallowed” as shown above.
Additional details, configuration, and logs
  • Both images are on the same version:
    • n8n main: n8nio/n8n:1.112.1
    • runners: n8nio/runners:1.112.1
  • External mode is enabled and runners connect successfully. Runners logs (debug) show they pass the allowlist variable names to the JS runner:
    2025/09/18 06:45:28 DEBUG [launcher:js] Env vars to pass to runner: [GENERIC_TIMEZONE N8N_RUNNERS_TASK_TIMEOUT PATH N8N_RUNNERS_TASK_BROKER_URI N8N_RUNNERS_HEALTH_CHECK_SERVER_ENABLED N8N_RUNNERS_HEALTH_CHECK_SERVER_PORT N8N_RUNNERS_AUTO_SHUTDOWN_TIMEOUT N8N_RUNNERS_TASK_TIMEOUT N8N_RUNNERS_HEALTH_CHECK_SERVER_HOST NODE_FUNCTION_ALLOW_BUILTIN NODE_FUNCTION_ALLOW_EXTERNAL]
    … connects to ws://app:5679 … offers/accepts tasks, launches runner, etc.
  • Allowlist environment variables are set on both the n8n main container and the runners container. I also tried a wildcard to allow everything:
    • NODE_FUNCTION_ALLOW_EXTERNAL=*
    • NODE_FUNCTION_ALLOW_BUILTIN=path,crypto
      Still, path and xlsx are disallowed in external mode.
  • External module installation and resolution:
    • Installed xlsx into the shared n8n data dir:
      npm ls xlsx --prefix /home/node/.n8n → shows xlsx@0.18.5
    • The same volume is mounted into the runners container at /home/node/.n8n.
    • runners container env includes: NODE_PATH=/home/node/.n8n/node_modules
  • Relevant docker-compose excerpts (only the relevant services shown):
app:
  image: n8nio/n8n:1.112.1
  container_name: n8n_app
  networks:
    - mcp-server
  environment:
    - N8N_RUNNERS_ENABLED=true
    - N8N_RUNNERS_MODE=external
    - N8N_RUNNERS_BROKER_LISTEN_ADDRESS=0.0.0.0
    - N8N_RUNNERS_AUTH_TOKEN=REDACTED
    - N8N_NATIVE_PYTHON_RUNNER=true
    - NODE_FUNCTION_ALLOW_EXTERNAL=*
    - NODE_FUNCTION_ALLOW_BUILTIN=path,crypto
    - GENERIC_TIMEZONE=Asia/Shanghai
    # DB and other envs omitted for brevity
  volumes:
    - /mnt/user/appdata/n8n/app:/home/node/.n8n
  ports:
    - "5678:5678"
task-runners:
  image: n8nio/runners:1.112.1
  container_name: n8n-runners
  networks:
    - mcp-server
  environment:
    - N8N_RUNNERS_TASK_BROKER_URI=http://app:5679
    - NODE_PATH=/home/node/.n8n/node_modules
    - N8N_RUNNERS_LAUNCHER_LOG_LEVEL=debug
  volumes:
  depends_on:
    - app
What I already tried
  • Verified both containers run the same version (1.112.1).
  • Set the allowlist on both the main n8n container and on the runners container.
  • Tried NODE_FUNCTION_ALLOW_EXTERNAL=* to allow everything.
  • Installed xlsx into /home/node/.n8n and mounted this volume into runners, setting NODE_PATH=/home/node/.n8n/node_modules.
  • External mode still blocks both built-in and external modules with “disallowed”.
  • In internal mode, the same Code nodes run fine.
Questions
  • Is there a known issue in 1.112.1 with how the broker enforces or passes the module allowlist to external runners?
  • Is there a way to verify what allowlist the broker actually sends to the JS task runner?
  • Any additional env or config required to allow built-in and external modules in external mode?
  • n8n version: 1.112.1 (Self-hosted)
  • Database: Postgres 15
  • n8n EXECUTIONS_PROCESS setting: default (own)
  • Running n8n via: Docker Compose (Linux host)
  • Operating system: Linux (Unraid host)
你好,你的问题解决了吗?
我也遇到类似的问题,用runner模式时,Code Node代码无法import 标准库或第3方库,
在code node运行如下代码:
import os
for item in _items:
item[“json”][“my_new_field”] = 1
return _items
仍报错:
Security violations detected
Line 2: Import of standard library module ‘os’ is disallowed. Allowed stdlib modules: none
Up. I have the same issue.
I”m using self-hosted n8n with NODE_FUNCTION_ALLOW_BUILTIN="*" in external task runner container. In the code node, I always get an error from const fs=require(“fs”).
To my understanding, self-hosted n8n should be able to use fs module in code node?
Same here, Module 'url' is disallowed [line 1]
despite adding BUILTIN=* and EXTERNAL=* for both n8n and runners containers.
The env variables are correctly loaded in the containers, but with no impact on the nodes.
One (cumbesome?) explanation could be there: Task runners | n8n Docs , but figured out it was faster for me to just not use that module.
