Hi, I don’t know if what I wrote in the subjet is the correct way to express my problem, but the thing is that an API sends the data I need inside something that is variable, let me show you:
What I need in my next node is the smtpStatus response, but since that comes nested inside the email, I don’t know how to call it from my IF node, because if I try this:
I’m leaving the email of my test hardcoded into the node, so the next email in the batch isn’t found.
I tired using regex in the expression, something like this:
{{$node[“VerificaMail2”].json[“(.*)”][“data”][“smtpStatus”]}}
But it didn’t work.
Then, from what I could understand from other posts in the forum, I have to flatten de json, but I couldn’t make it work.
I’m sorry if I don’t make any sense, I don’t know much about javascript or json name of things, I hope I was able to express my problem. I’ll try to clarify more if you need.
Thank you for your time.
Pablo T.
