Extract data from Json not fixed position
Hello there,
I get data from a json where there are tons of information.
Right now I just get the data I need using the position of the information needed.
Like this:
{{$node["Consulta API Victron"].json["records"][167]["rawValue"]}}
That works well … until the position change and is not 167 anymore and the node fails.
What would be the way to get a value from the json by a key other than the position.
The json is like this:
"success": true,
"records": [
"idSite": 111111,
"timestamp": 1701917871,
"Device": "Gateway",
"instance": 0,
"idDataAttribute": 1,
"description": "gatewayID",
"formatWithUnit": "%s",
"dbusServiceType": null,
"dbusPath": null,
"code": "d",
"bitmask": 0,
"formattedValue": "Venus OS",
"rawValue": 2,
"dataAttributeEnumValues": [
"nameEnum": "VGR, VGR2 or VER",
"valueEnum": 0
"nameEnum": "Venus OS",
"valueEnum": 1
"valueEnum": 2
"nameEnum": "Coupling / GlobalLink",
"valueEnum": 3
"nameEnum": "PHYSEE NodeMCU",
"valueEnum": 4
"id": 1
"idSite": 111111,
"instance": 0,
"idDataAttribute": 386,
"description": "Productid",
"dbusPath": null,
"code": "mi",
"bitmask": 0,
"formattedValue": "C002",
"rawValue": "C002",
"id": 2
"idSite": 111111,
"instance": 0,
"idDataAttribute": 387,
"description": "MachineName",
"dbusPath": null,
"code": "mn",
"bitmask": 0,
"formattedValue": "Venus GX",
"rawValue": "Venus GX",
"id": 3
I would like to get the value (for example) of "description": "gatewayID",
  • n8n version: 0.189.1
  • Database: SQLite
  • n8n EXECUTIONS_PROCESS setting: default
  • Running n8n via npm
  • Operating system: Linux
Hey @RichiWalichi,
If you have a value that is fixed that you know so in your case you know the description will contain Gateway you could use a code node to loop over the array or use a Split Out node to convert the array to items then use an If node, Swtich node or something else to find the values you are after like the example below.
Or use Query JSON with JMESPath | n8n Docs
Many thanks @pemontto and @Jon, thanks to your help I’ve able to get the value.
Eventually I’ve use JMESPath with this value:
let battery = $jmespath($json.records, "[?description=='State of charge'].rawValue" )
return {battery};
Search in the Json the label description and if it has “State of charge” then get the rawValue.
Many thanks for the help :wink:
I always forget about JMESPath, I still don’t think I have used it :slight_smile: This seems like a great use for it.
