Hi people! I’m extracting a body of text from an RSS feed that contains multiple values inside that I’d like to extract and save to my Airtable.
For example, from this body of text below I would like to save Hourly Rate, Skills, Category, etc… in separate values to save it in separate columns on Airtable.
What would be the easiest way of doing this? I appreciate any help you can provide.
Extracting information from arbitrary text written for humans can be a bit painful.
However, assuming certain keywords are always present in your RSS feed you could use regular expressions to read such information in n8n. Unfortunately you only shared a screenshot rather than the full JSON data your currently have, so I can’t provide an example for your actual dataset, but something like this should do the job:
This will give you the information in individual fields which you can then send to Airtable or any other service:
