Please help i am facing issue in self hosted interface of n8n i have create ec2 instance of t3 small my server is nginx i am using this as reverse proxy and i have pull the docker image of n8n from docker hub that is official one see what the issue is when i create the owner i.e (/setup) so it assigns the owner now when i create credentials sometimes it gets created and sometimes it does not show the credentials now when i do refresh the route redirect again me to (/setup) now i can’t login again as the login route is not working and not available also if the credential get created than i can’t delete and if sometimes by luck i am able to delete than when i add new credential the deleted one appears again please help where is the problem coming from? does the image of n8n has bugs inside it?? please help me guys
Hey @Naimish_Dusara !! Hope you are doing great!! I have running a similar instance scenario so I wonder if you are still facing the issue? If so, may be I can help!
