Failed to get items from DynamoDB using an index
I’m trying to get DynamoDB items using filters from a specific index and I’m getting the following error message:
ERROR: Cannot read property ‘message’ of undefined
I’m not quite sure if I’m missing something. I’m successfully inserting items with the same credentials, but still can’t get the items properly.
  • n8n version: 0.153.0
  • Database you’re using: PostgreSQL
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
Hey @marcos.martinewski,
welcome to the community :tada:
I am not an experienced with DynamoDB, it looks like the error could come from here. That’s just a guess but it would apparently mean that The AWS credentials are not valid!.
If you remove your Key Condition Expression does it work then? I see that you are using retaierId = : retailerId AND status = :status. Maybe you need to remove a space to use :retailerId instead of : retailerId.
Hi, Marcus. Thanks for the reply. I tested the credentials and it is working. But I’ll try to remove that space at retailerId to see if works. I tried so many things, so I think I’m getting a little bit careless.
Yep, tried removing that space in :retailerId and didn’t work. I’ll try other things while I don’t get a solution.
