Firestore create reference in document
Hello,
I am trying to insert a reference to a document inside s document in Firestore with no luck.
This is the input data:
And it is inserted as strings:
However, I’d need to insert them as references to other documents, like here:
Is there any way to do this?
I’m answering to myself :slight_smile:
Digging on the module code, I’ve seen that it is not possible to add data as referenceValue in the default Firestore module.
I’ve patched it for me, so I’d like to ask you what is the preferred way of contributing back with my fix.
  • Sending a PR
  • Wrapping the patch in a community module
Thank you,
Hi @Albuendi, welcome to the community :tada:
Seems like you figured it out already. The basic process of creating a community node would be described here: Creating nodes - n8n Documentation. This is usually the fastest way of making a new node available to other users.
We also welcome PRs for improving existing nodes, though it might take us some time to get through them unfortunately. The dev guidelines would be available here: n8n/CONTRIBUTING.md at master · n8n-io/n8n · GitHub
Thank you so much!
Hey, would you share how did you fixed it?
I urgently need this feature :slight_smile:
You did it? I have the same problem.
Bonjour,
Same probleme here, trying to create a document using Google Cloud Firestore node. and like few of us, one of my field is a document reference which is still not accepted on n8n. Any solution so far? i am struggling a bit and there are no video on youtube talking about that issue
