Firestore "Undefined" issue, despite an accurate existing doc ID and collection
Hi All,
I’ve been struggling with this for a while now, unsure why this is happeing…
Issue: Data is being written to firestore collection as an “undefined document”
Steps…
1- We retreive an existing document form firestore by using its ID (successful)
2- We use a SET node to update one of the fields with the current timedate when the n8n flow runs
3- We write back to the exact same document, specify the collection and document ID…
Result: undefined document is created in firestore
Here is the flow (just the beginning)
If I had any hair left I would pull it out :upside_down_face:
Please, rescue me.
Solution:
Do not give it the actual key
Give it the name of the column/field where the key is stored.
The documentation for the firestore node needs significant work
Glad to hear you figured it out and thanks so much for sharing your feedback on the docs @Alex_Cvitanovic! I’ll make sure to pass it on to the team.
