Hi everyone,
I’m trying to build a workflow that uses an MCP Server Trigger to return the temperature of a location (via the OpenWeatherMap API).
The idea is:
- MCP Server Trigger receives a request
- I set a zipcode and country
- I fetch the weather using
HTTP Request - I format the response using a
Codenode
My problem: I can’t finalize the MCP Server Trigger part so that it properly returns the weather data. At the moment, I’m not sure how to connect the output from the Code node so the MCP Server actually sends it back.
Does anyone have an example or guidance on how to return the response correctly from the MCP Server Trigger?
No explicit error, but the MCP Trigger doesn’t return anything when I test it.
Currently, my Code node returns this JSON:
"ville": "Paris",
"temperature": "18°C",
"ressenti": "17°C",
"meteo": "clear sky",
"humidite": "55%",
"vent": "3 m/s"
But I’m not sure if this is the correct format for the MCP Server Trigger to return as output.
- n8n version: 1.113.3
- Database: Postgres 16 (alpine image)
- n8n EXECUTIONS_PROCESS setting: own (default)
- Running n8n via: Docker
- Operating system: Debian 13 (Linux)
