I’m currently working on this tutorial A longer introduction | n8n Docs
This is what Postbin looked like
This can’t be right? It doesn’t even show what I specified in Bin Content
PostBin is a tool primarily used for debugging and testing web applications and APIs. It allows you to inspect the raw HTTP requests sent to a specific endpoint.
This is invaluable for understanding exactly what your application or API client is sending, which helps you quickly identify and resolve any issues.
Why not try this link to see PostBin in action? https://www.postb.in/1746875746493-6344902946148?hello=world
So, don’t put too much emphasis on the content.
Hope I have solved your problem/
Thanks! I can’t access the link, do you mean it’s expected the content won’t appear in the postbin site?
You have to change your bin ID, so you can see your access URL
