I have an unusual issue with one of my flows. It seems to never stop. I’ve never had any issues like this before and when I run the same data through in a test it does complete. But on production call it gets to the if node and just hangs there, every time.
Unfortunately I can share the entire flow since there are needed but these are the last steps and it there is nothing that should be causing it to fail. I even put a 5 min timeout on it and it was running for over 800 minutes before I noticed and canceled it.
I’m not sure if the test data output will show in the example of the call workflow node, but below is its output.
"errors": [],
"success": true,
"Message": "Files successfully uploaded.",
"Successes": [
"litify_docs__Version_Id__c": "TgpWi2J6p76_SsTEMLnH.lR5X6y3NTMl",
"litify_docs__Source__c": "Docrio Api",
"litify_docs__File_Size__c": 51643,
"litify_docs__Has_Attachments_Legacy__c": false,
"litify_docs__Updated_By_Name__c": "Philip Wiggins",
"litify_docs__Delete__c": false,
"litify_docs__Updated_On__c": "2023-12-12T01:01:42.815Z",
"litify_docs__Updated_By__c": "00546000001pssAAAQ",
"litify_docs__Folder_Path_Last_255__c": "[]",
"litify_docs__Folder_Path_First_255__c": "[]",
"litify_docs__Latest_Version_Formula__c": 0,
"litify_docs__Folder_Path__c": "[]",
"litify_docs__OCR_Compatible__c": true,
"litify_docs__Latest_Version__c": 0,
"litify_docs__Related_To__c": "a0I8Z00000Mg4nMUAR",
"litify_docs__Related_To_Api_Name__c": "litify_pm__Matter__c",
"litify_docs__File_Type__c": "application/pdf",
"litify_docs__File_Link__c": "/lightning/r/litify_docs__File_Info__c/a2W8Z000014NjWL/view",
"litify_docs__Complete__c": true,
"SystemModstamp": "2023-12-12T01:01:37.000Z",
"LastModifiedById": "00546000001pssAAAQ",
"LastModifiedDate": "2023-12-12T01:01:37.000Z",
"CreatedById": "00546000001pssAAAQ",
"CreatedDate": "2023-12-12T01:01:37.000Z",
"Name": "Test, Betty - Questionnaire.pdf",
"IsDeleted": false,
"OwnerId": "00546000001pssAAAQ",
"Id": "a2W8Z000014NjWLUA0"
"Failures": [],
"sfToken": "redacted",
- n8n version: 1.20.00
- Running n8n via CLOUD
