Hello,
Although my automatically started flows with cron have been active for 6 months, they have not been working automatically for the last 3 days.
When I click Execute Workflow it works fine.
HI @emretekin
Welcome to the community ![]()
Can you share what your workflow looks like and how you’re trying to schedule? Also, are you using n8n cloud or self-hosting? If self-hosting, have you made any changes to your setup?
Could you also share the following:
- n8n version:
- Database (default: SQLite):
- Operating system:
I am using N8N Cloud. The entire workflow was working smoothly until the last week.
I’m adding one of the workflows that doesn’t work below. It runs when I only click Execute Workflow.
Hi @emretekin - by those screenshots, you’re on a very old version of n8n. Could you please try upgrading through your admin panel on cloud and seeing if the issue still persists? While you’re there, it would also be a smart idea to double check your timezone settings ![]()
If it still happens, could you try replacing the old Cron trigger node with the new Schedule trigger node? ![]()
Thank you very much, upgrading worked. ![]()
