Folders for Organization in UI
Hey Community!
Does anyone know of a method to organize all of your workflows? Right now, I’m using tags and it is becoming unwieldy and disorganized.
The ability to organize in folders seems like the optimal solution.
Is this possible or how are others organizing them?
Hey @dstarr , n8n uses notion of projects instead of folders. However, the maximum number of projects available depends on the plan you subscribed:
Community: 0
Starter: 1
Pro: 3
Enterprise: unlimited
We have considered adding folders in addition to projects but that is not yet worked finalized.
Thanks! This would be the first pricing concept to do with folders that I’ve come across.
Folders regardless of the plan seems like a beneficial way for users to scale out the technology for their company in an organized fashion.
@ihortom
Is there anyway to increase the number of projects on a plan? We have a client on pro that doesn’t need anywhere near that level of executions but having more projects would be beneficial to facility workflow reuse.
Thanks
Welcome to the community @Dave_Schafer !
I’m afraid the sharing feature is not something that could be adjusted on the standard plans. The only threshold that could be customized once the user is on PRO-2 plan is the maximum monthly executions and active workflows.
