Getting this issue after integrating ssl certs and nginx
what is the possible fix
Try adding this environment variable to your n8n environment/startup
N8N_PUSH_BACKEND=websocket
I also added these to my docker instance behind nginx. I honestly don’t remember why I left that VUE one ‘internal’ vs external, but it wasn’t an accident
-e VUE_APP_URL_BASE_API=http://192.168.0.14:5678
-e N8N_TEMPLATES_ENABLED=true -e N8N_PROXY_HOPS=1
-e N8N_HOST=https://myinstance.mydomain.com
-e N8N_EDITOR_BASE_URL=https://myinstance.mydomain.com
-e WEBHOOK_URL=https://myinstance.mydomain.com
Make sure your NGINX config includes the following for the WebSocket upgrade:
nginx
CopyEdit
location / {
proxy_pass http://localhost:5678; # Adjust if your n8n port differs
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
Also, ensure your server block has:
nginx
CopyEdit
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
Make sure this block is under your server { listen 443 ssl; } block, not just for port 80.
