This is an automation that works on your technical SEO aspects to give a detailed overview of all the data and detail you have on n8n
Example analysis for page n8n.io. You also get a copy of the results on your Google sheets account
wow… that look amazing…
good job man…
is the template for sharing / sale.
Hello… Yeah… Its on Gumroad
With a bunch of other SEO workflows
I’ve been doing something similar with audits and feeding results into Sheets too. For link profiles, I added a step that pulls referring domains and anchors, then match those against outputs from a link building outreach service to spot any gaps or targets worth chasing. It’s been helpful to see where links are missing.
