I often need to extract the first name from a full name in all caps (“CLARA SMITH”) and convert it to title case (“Clara”)
Is there a simple way in n8n to do that?
You can .split(' ')[0]
on the space char to get the first name, and use the handy data transform function to title case it Data transformation functions for strings | n8n Docs
It worked beautifully with toSentenceCase():
{{ $(‘Split In Batches’).item.json[“salesperson_name”].split(" ")[0].toSentenceCase() }}
