I want to forward binary data from an input of a code-block as binary output + json output from Code-block to nextcloud block.
So in nextcloud-block I would need:
- Binary forwarded inside code as binary
not working
- yearmonth from code
works fine
- year from code
works fine
Please share the workflow
- n8n version: 0.198.2
- Database you’re using (default: SQLite):default
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:docker
