Frequent Logout Issue - "browserId check failed
Hi everyone,
I’m experiencing an issue where I keep getting logged out of n8n multiple times an hour. In the logs, I see the following errors repeatedly:
2024-11-25T21:01:41.132176489Z browserId check failed on /rest/events/session-started
2024-11-25T21:01:41.214151689Z browserId check failed on /rest/login
It’s frustrating to have to log in again and again. Has anyone faced this issue before, or does anyone know how to fix it?
instance information
Debug info
core
  • n8nVersion: 1.68.0
  • nodeJsVersion: 20.18.0
  • database: postgres
  • executionMode: regular
  • concurrency: -1
  • license: community
  • consumerId: unknown
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
pruning
  • enabled: true
  • maxAge: 336 hours
  • maxCount: 10000 executions
client
  • userAgent: mozilla/5.0 (macintosh; intel mac os x 10_15_7) applewebkit/537.36 (khtml, like gecko) chrome/131.0.0.0 safari/537.36
  • isTouchDevice: false
Generated at: 2024-11-25T22:38:37.794Z
Hi @nusquama!
Are you connecting to different n8n instances? Can you try running it on private browsing mode and see what happens? Do you have any browser add-ons enabled?
Can you check if the docker container is restarting often?
