G Drive connection - Request failed with status code 403
Hi everyone,
I have connected my Google account to n8n and set everything up correctly. I can access the folder names and IDs, but I’m unable to download the files. I keep getting the following error message. I’ve already tried resetting OAuth, enabling and disabling the API connection, and reconnecting the account in n8n, but nothing seems to work.
Can someone please help me out?
Forbidden - perhaps check your credentials?
In your Google Cloud Console, make sure you have all the Google Drive scopes listed here:
If you don’t, add them manually.
:muscle: If my reply answers your question, please remember to mark it as a solution.
Thank you! This helps!
