Gather trigger and actions together in custom node
Hi !
I am building a custom node, and I would like to gather my trigger and my actions in the UI. For the moment, when searching for my service, both appears (trigger and action). However, I would like just one row to appear (like Brevo for example), and inside the node, having the ability to select an action or a trigger.
Current behavior:
Desired behavior:
then
I could not find an attribute leading to that in Brevo node implementation.
Thank you for your help!
  • n8n version: 1.67.1
  • Operating system: MacOS
hello @HenriChabert
I would try setting the displayName the same for the node and credential in the .ts files
e.g. Brevo node
Brevo creds
