Gemini pro 1.5 exp error
I have error when i use gemini-1.5-pro-exp-0827
GoogleGenerativeAI Error]: Error fetching from https://generativelanguage.googleapis.com/v1beta/models/gemini-1.5-pro-exp-0827:generateContent: [429 Too Many Requests] Resource has been exhausted (e.g. check quota).
Quota is ok.
any idea ?
Debug info
core
  • n8nVersion: 1.56.2
  • nodeJsVersion: 20.15.0
  • database: postgres
  • executionMode: regular
  • concurrency: -1
  • license: community
  • consumerId: unknown
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
pruning
  • enabled: true
  • maxAge: 336 hours
  • maxCount: 10000 executions
Generated at: 2024-09-07T19:11:09.646Z
You’re running from the Gemini node, correct? Have you tried running from the HTTP Request node using the cURL syntax from the Gemini documentation? I personally get less weird errors when I do it that way.
