General understanding of workflow compared to Zapier
Hi together,
We want to move away from Zapier because of some limitations. At the moment we do have like 200+ active Zaps. In n8n I can have up to 50 active workflows. Current scenario: we do have a Zap in Zapier for whenever you receive a Google My Business review, we will answer to that with a ChatGPT generated answer. Question: will this then be one active workflow? Because if I have like 100+ GMB accounts, I will need 100+ active workflows, then the pricing model will be more expensive here, or? Maybe I am just thinking the wrong way.
Thanks for all the help.
Regards,
Soeren
Hey @Soren
It depends on how you organize your workflows. In n8n you have a lot of flexibility. For example one solution for your use-case would be to have multiple triggers in the same workflow and set all fields right after the triggers:
Another way will be to have one workflow with all of the triggers and call a subworkflow for the reply:
Workflows that have only the ‘When executed by another workflow’ trigger can’t be activated and i think don’t count towards the active workflow count.
