This is a simple workflow that can be used to generate several keywords using the Google autosuggest Function.
To do this you need to send HTTP requests to the google autogenerate endpoint and you get up to 10 keywords per search. This will pretty sure save you lots of time in keyword research
I’ve tried this Google Autosuggest trick before, and it’s a game-changer for quick keyword ideas! I used it when I was updating my site’s blog for my plumbing business and wanted to target long-tail keywords like “fix a leaky tap DIY.” It really saved me hours compared to brainstorming or using paid tools.
It really saved me hours compared to brainstorming or using paid tools.One thing I realized, though, is that while it’s great for ideas, understanding which keywords have real search volume and potential can be tricky. That’s when I reached out for UK SEO services to get deeper insights and refine my strategy. They helped me turn those raw suggestions into a focused list that actually brought in traffic.
Generating keywords for SEO starts with understanding what your audience is actually searching for, not just guessing topics. The goal is to find real search terms that match intent—whether someone is looking to buy, learn, or compare something. A good approach is to start with a core topic, then expand it into variations like questions, long-tail phrases, and related terms.
One of the easiest ways to do this is by using Google’s autocomplete, “People also ask” section, and related searches at the bottom of results pages. These give you real queries people are already typing. You can also analyze competitors’ pages to see what keywords they are targeting and identify gaps you can fill.
Tools can speed this process up a lot. For example, Google Keyword Planner helps estimate search volume, while other platforms suggest keyword clusters and related ideas. You can also use Free Web SEO Tools to quickly explore keyword opportunities and get a better sense of what might work for your niche without needing expensive software.
The key is not just collecting keywords, but organizing them into groups based on intent and building content around those groups. That’s what actually helps improve rankings and traffic over time.
