Generic method to send SMS using HTTP API
Hi,
There are many SMS providers. And it is hard to implement them all.
Most of them provide an easy way that is to send SMS via HTTP API.
So we can simply add URL parameters after the base URL and everything is done.
There are some common parameters (the parameters’ names may vary in different providers):
  • base URL
  • user_name
  • PWD
  • Subject (optional)
  • receiver
  • text
  • scheduledatetime
Thanks
According to this article
This can be done using http request node.
yeah, as long as these sms providers expose a REST API this can be achieved with the HTTP node.
I found a provider that submits SMS wordwide for only 7 euro cents. per Message.
bute best of all. you are able to provide a NAME as sender..
