Get parameters with their type from SET node
hi, i have set node and after that i have function node, in the set node i have 3 props
1 boolean true
2 number 55
3 string blabla
i want in function node to use javascript to get all the props from set node and also to get their type
how can I do that?
thanks
SQLite
main
npm
windows server 2019
i use typeof in js
for (const item in items[0].json) {
console.log(typeof(items[0].json[item]))
Hi @Asaf_Shay
Not sure what you are trying to do here.
Could you give an example of the workflow and data with an expected output of this data?
