Get Top (or Best) posts from a Subreddit?
I’m trying to get the Top (or Best) posts from a Subreddit and create content on Instagram from them.
Is there a way to do this?
The URL would be: https://www.reddit.com/r/*subredditname*/top
Thank you
Hi @Pha_Prod
Welcome to the n8n community :tada:
I’m answering the Reddit part since I’m not sure about the Instagram Part.
If you add .json at the end of the Subreddit URL, you’ll get a nice JSON with the all details in it.
Here are the examples.
General:
https://www.reddit.com/r/awww.json
Top:
https://www.reddit.com/r/awww/top.json
Best:
https://www.reddit.com/r/awww/best.json
You can also limit the number of response
https://www.reddit.com/r/awww/top.json?limit=100
Also, for the Instagram part. Afaik. You need Access Token. With that, you have to get the Refresh Token, Create a post container, and push the actual image URL.
Feel free to refer to this documentation. You’ll be using HTTP Nodes inside n8n.
Thank you so much, that worked!
