Get values with no duplicates
Hi, I wanted to get data of an item that has no duplicate.
Here is an example of the data I got using merge node
I want to get ID 6998874, since it doesn’t have a duplicate value. How can I go about this using function node?
Hey @zocket,
Do you just want that one value or do you want to remove all duplicates (the item list node can do this)?
i needed the one value, that has no duplicates
Here is an example data. I want to only get values 15 and 16
Hi @zocket, I was having a look at the example data provided and tried to keep the non-duplicate values using the Merge and Item Lists node but couldn’t come up with a working approach that would only let you keep unique values.
So unless someone else has a nice idea for this that has not come to my mind I’d write a quick helper function counting the occurrences of each ID. You could then use the IF node to filter those with only one occurrence.
Example Workflow
Does this help you?
Thanks so much. This has helped solved my issue.
Nice, glad to hear that (though it bothers me I couldn’t come with a code-free approach :see_no_evil:).
Thanks so much for confirming!
Hi @MutedJam i was searching for something like this but let’s say I have two different columns to summarize how do you approach to that problem?
Hey @MaaPer,
It might be worth opening a new thread as we have had new nodes added since November last year although it would still be possible with code.
If we can get a sample of the data and what you would expected to see we can take a look for now though I am going to close this thread.
