Hi, i’m new to n8n, i was testing if i could use n8n to handle some http requests as a man in the middle for credentials validation, i have a webhook wich recieves a json, it work, but when i try to set this value into a new http request node using expression {{$node[“Set”].json[“body”]}} i get a prefix to the raw data and it results into this
I’m guessing you either just want to reference the id of the data and that can be done like this
{{$node[“Set”].json[“body”][“id”]}}
{{$node[“Set”].json[“body”][“data”]}}
About sharing the workflows, yes, this is wat of sharing workflows. For something reason, the workflow you pasted had “ and ” instead of " and ". I had to replace them.
You actually do not have to care about the [Object: ...] it will not be transmitted. It is only a visual indication that shows that it is an actually JavaScript object.
So it will already work as you expect it to work. If you however want to see it (for your visual pleasure) without it you can simply wrap it in JSON.stringify(...).
