the new code node is not working with getWorkflowStaticData(‘global’).
- n8n version: 0.234.1
- Database (default: SQLite):
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: MAC
netroy
2
There seems to be a typo in your code.
Can you please try replacing getWorkflowStaticata('global') with $getWorkflowStaticData('global')?
@netroy
Fixed but raised another issue
May you please check this workflow
hope you got to know what I need.
Thanks in advance
netroy
4
The error message suggests that you need to replace item.propertyName with item.json.propertyName.
system
Closed
7
