GGSheet Read
Hy, i have a problema, my google sheet node, in mode read,
is skipping 2 lines in reading
Hey @salvioni13,
Welcome to the community :sparkling_heart:
Can share more information? If you can share your workflow or even the screenshot of the node, it will help us understand better.
Hey @salvioni13,
Thanks for sharing your workflow. I tried replicating the issue, but I couldn’t. The Google Sheets node returns all the items for my sheet.
Hey @salvioni13,
Did you fix it? Let me know if you are still facing the same issue.
As mentioned, I was not able to replicate the issue. If you could share your Sheet it might help :slight_smile:
