Hi folks,
I’ve already set up the Ghost node to post articles, but I’m getting an error. Has anyone encountered this kind of behaviour?
OUTPUT Table JSON Schema 1 item
n8n version: Docker image: n8nio/n8n:latest
Database (default: SQLite): not using via docker-compose
n8n EXECUTIONS_PROCESS setting (default: own, main): main
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: Ubuntu 22.04
Hi @organicnz , I can’t see an error on your screenshot, although the empty response does look very much unexpected to me.
Are you simply not seeing a response? Or is the post also missing in Ghost? If so, are you seeing the same behaviour when using hard-coded text values in the node instead of expression referencing incoming data?
Edit: From testing this locally, I am seeing the expected response in n8n:
This was my docker compose setup:
services:
postgres:
image: postgres:11
restart: unless-stopped
environment:
- POSTGRES_USER=n8n
- POSTGRES_PASSWORD=n8n
- POSTGRES_DB=n8n
volumes:
- ./db_data:/var/lib/postgresql/data
ports:
- 5432:5432
healthcheck:
test: ['CMD-SHELL', 'pg_isready -h localhost -U n8n -d n8n']
interval: 5s
timeout: 5s
retries: 10
n8n:
image: n8nio/n8n:0.224.1
environment:
- DB_TYPE=postgresdb
- DB_POSTGRESDB_DATABASE=n8n
- DB_POSTGRESDB_USER=n8n
- DB_POSTGRESDB_PASSWORD=n8n
- DB_POSTGRESDB_HOST=postgres
volumes:
- ./data:/home/node/.n8n
ports:
- 5678:5678
depends_on:
postgres:
condition: service_healthy
ghost:
image: ghost:latest
environment:
NODE_ENV: development
database__connection__filename: '/var/lib/ghost/content/data/ghost.db'
ports:
- 2368:2368
volumes:
- ./ghost:/var/lib/ghost/content
Workflow:
Perhaps you can also share the JSON dataset your IF node is passing on to your Ghost node?
Hey hey, @MutedJam . Thank you very much for your reply
Apologies, I didn’t describe so many details. Yeah, I saw the missed messages and I also tried hard-coded text but encountered the same result, unfortunately. So, I’m currently trying to switch from CloudFlare Zero Trust to Caddy for Ghost as well as I’ve already done the same thing with n8n. I’ll keep you posted. Hope this helps, hehe
Hey @MutedJam . My suspicions were justified, it was a Cloudflare Zero Trust tunnel. So I’ve just switched to the same Caddy container I’ve been using for n8n and proxied from my external droplet IP to CloudFlare without setting up the tunnel. It’s working pretty well so far. The n8n doesn’t really seem to like CF Zero Trust lol. Maybe someone can figure it out or has already successfully configured it with ZT. It would be nice to know how to do it
Thanks so much for your help
cat ./n8n/docker-compose.yml
version: "3.7"
services:
caddy:
image: caddy:latest
ports:
- "80:80"
- "443:443"
volumes:
- ${DATA_FOLDER}/caddy_data:/data
- ${DATA_FOLDER}/caddy_config:/config
- ${DATA_FOLDER}/caddy_config/Caddyfile:/etc/caddy/Caddyfile
networks:
- no-zero-trust-cloudflared
- web
n8n:
restart: always
ports:
- 5678:5678
environment:
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER
- N8N_BASIC_AUTH_PASSWORD
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- N8N_EMAIL_MODE=${N8N_EMAIL_MODE}
- N8N_SMTP_HOST=${N8N_SMTP_HOST}
- N8N_SMTP_PORT=${N8N_SMTP_PORT}
- N8N_SMTP_USER=${N8N_SMTP_USER}
- N8N_SMTP_PASS=${N8N_SMTP_PASS}
- N8N_SMTP_SENDER=${N8N_SMTP_SENDER}
- N8N_SMTP_SSL=${N8N_SMTP_SSL}
#- PUID='1001'
#- PGID='1001'
#user: "${UID:-1000}:${GID:-1000}"
- NODE_FUNCTION_ALLOW_EXTERNAL=uuid
volumes:
- ${DATA_FOLDER}/local_files:/files
- ${DATA_FOLDER}/.n8n:/home/node/.n8n
mem_limit: "1g"
mem_reservation: "1g"
cpus: 1
cpuset: "0"
networks:
networks:
web:
external: true
no-zero-trust-cloudflared:
external: false
driver: bridge
volumes:
caddy_data:
external: true
caddy_config:
cat ./n8n/caddy_config/Caddyfile
# Global options block. Entirely optional, https is on by default
# Optional email key for lets encrypt
email [email protected]
# Optional staging lets encrypt for testing. Comment out for production.
# acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
n8n.foodshare.club {
encode zstd gzip
reverse_proxy n8n-docker-caddy-n8n-1:5678 {
flush_interval -1
header {
# enable HSTS
Strict-Transport-Security max-age=31536000;
# disable clients from sniffing the media type
X-Content-Type-Options nosniff
# clickjacking protection
X-Frame-Options DENY
# keep referrer data off of HTTP connections
Referrer-Policy no-referrer-when-downgrade
# Content-Security-Policy: default-src 'self'
www.n8n.foodshare.club {
redir https://n8n.foodshare.club{uri}
blog.foodshare.club {
encode zstd gzip
reverse_proxy ghost:2368
header {
# enable HSTS
www.blog.foodshare.club {
redir https://blog.foodshare.club{uri}
cat ./ghost/docker-compose.yml
version: '3.7'
services:
ghost:
image: ghost:latest
container_name: ghost # change as necessary
ports:
- '2368:2368'
volumes:
- ./ghost-data:/var/lib/ghost/content
- /etc/localtime:/etc/localtime:ro
networks:
# - docker-network
environment:
# see https://ghost.org/docs/config/#configuration-options
database__client: mysql
database__connection__host: db
database__connection__user: user
database__connection__password: password
database__connection__database: password
url: https://blog.foodshare.club
NODE_ENV: production
mail__transport: "${MAIL_TRANSPORT}"
mail__options__host: "${MAIL_HOST}"
mail__options__port: "${MAIL_PORT}"
mail__options__secureConnection: "${MAIL_SECURE_CONNECTION}"
mail__options__auth__user: "${MAIL_USER}"
mail__options__auth__pass: "${MAIL_PASSWORD}"
links:
- database
database:
image: mysql:latest
volumes:
- ./ghost-db:/var/lib/mysql
ports:
- "13928:3306"
environment:
MYSQL_ROOT_PASSWORD: "${MYSQL_ROOT_PASSWORD}"
MYSQL_DATABASE: "${MYSQL_DATABASE}"
MYSQL_USER: "${MYSQL_USER}"
MYSQL_PASSWORD: "${MYSQL_PASSWORD}"
cap_add:
- SYS_NICE
networks:
# - docker-network
networks:
web:
external: true
external: false
driver: bridge
volumes:
ghost-data:
ghost-db:
system
Closed
April 26, 2023, 10:15pm
5
