Hi n8n community,
I’m working with the GitHub “Get Issue” operation and need to filter issues that do NOT have a specific label. Specifically, I want to achieve the equivalent of GitHub’s -label:Stale filter syntax.
What I’m trying to achieve:
- Retrieve issues from a GitHub repository
- Exclude any issues that have the “Stale” label
- This is similar to using
-label:Stalein GitHub’s search interface
What I’ve tried:
- Looking through the available filter options in the GitHub Get Issue node
- Checking if there’s a way to use negative filtering in the current filters
Questions:
- Is there a way to configure the current filters to exclude issues with specific labels?
- Are there alternative operations or workarounds that could achieve this filtering?
- If this functionality isn’t currently available, I’d appreciate knowing that as well so I can plan alternative approaches.
Any guidance would be greatly appreciated! Even confirmation that “this isn’t currently possible” would be helpful for planning my workflow.
Thanks in advance!
