Trying to read gitlab repository information using gitlab access token
“message”: “self signed certificate in certificate chain”,
“name”: “Error”,
“stack”: “Error: self signed certificate in certificate chain at TLSSocket.onConnectSecure (_tls_wrap.js:1497:34) at TLSSocket.emit (events.js:315:20) at TLSSocket._finishInit (_tls_wrap.js:932:8) at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:706:12)”,
“code”: “SELF_SIGNED_CERT_IN_CHAIN”
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
**n8n version: 0.178.2
**Database you’re using (default: SQLite):SQLite
**Running n8n with the execution process [own(default), main]: Browser
Running n8n via [Docker, npm, n8n.cloud, desktop app]:
Can you fill out all of the template so that we know how you are running n8n and what version you are using.
Are you self hosting Gitlab as well? The error looks like you are using a self signed certificate and we don’t have an option to ignore certificate errors with the Gitlab node at the moment.
Really? That surprises me. Is it npm, docker or desktop?
Sadly if you are getting a self signed certificate back it is going to be something on your network like a proxy or AV trying to do content inspection or there is something wrong with Gitlab.
The only thing we could do is add an option to ignore cert errors but in cases like this it is probably good to know something is possibly intercepting your traffic.
Any proxy or AV installed that is doing content inspection? At the moment everything I have is above.
We probably should add an option to ignore cert issues as it can be set hosted but if you are going from your machine to their server you shouldn’t be getting issues like this.
