Gitlab Trigger self hosted 'Project not found'
Hello, I just install n8n. I’m trying to setup a Gitlab Trigger. Made the connexion with Access Token works fine. But when I’m trying to add a node with a project I get “404 Project not found”
No data since it does work
  • n8n version: Version 0.231.3
  • Database: SQLite
  • Operating system: docker
Hi @Raphael_Teyssandier - welcome to the community :cake:
Out of curiousity, are you connecting to a Gitlab repo that is owned by an organisation? If it’s a company repo instead of a personal one, the ‘Repository Owner’ value won’t be your username but instead the string after the gitlab.com/ portion in the URL.
If that doesn’t help fix it up, can you tell us a little bit more about your setup and if you’re running Gitlab locally or not?
Thank’s, it was exactly that !
