Gmail email body data
Hello,
I’m reading an email message from Gmail to get an email message in text format to save on google sheet but this data is not coming in human-readable format, would you please guide how I can get this email message in a readable format?
Best Regards.
You should have a test property in the response.
Thanks for the response @RicardoE105 i do not see that text property in the response, any idea why its not appearing?
No idea. I tested it retrieving ten emails, and all of them came with the property text. Is the Gmail node the only one you are using? Is it possible that a set node or function node overrides this property?
When i selected the Format as Resolved then i was able to see that property thank you so much for your help!
